Author Topic: License server - remove licenses?  (Read 8435 times)
George
« on: March 21, 2012, 05:18:16 am »
How do I remove licenses? I have a few inactive ones like a beta license, etc.
Re: License server - remove licenses?
« Reply #1 on: March 21, 2012, 08:30:55 am »
Select it in the License Manager and click Shift+Del.
link3d
« Reply #2 on: March 22, 2012, 05:33:45 pm »
I would like to change from xp64 to win7 on the same machine. Can i just save the activation status code, Hardware ID, and forest serial to reactivate the license after a complete reinstall?
Matthias
« Reply #3 on: March 22, 2012, 05:38:07 pm »
No, a Windows reinstallation changes the machine ID. You must reactivate the license.
NL2911
« Reply #4 on: April 25, 2012, 01:22:49 pm »
What is de best way to do if you change workstation?
The license manager won't let me delete or disable the license on comp A i can only add a license/
"ï just found out that you can install with the same key to switch"
« Last Edit: April 25, 2012, 01:31:18 pm by NL2911 »
« Reply #5 on: April 25, 2012, 01:52:56 pm »
Yes, there is not a procedure to uninstall the license. Just install and activated it in the new computer.
If for some reason you need to remove a installed license (for example, to replace it with a new one), select it in the License Manager and click Shift+Del.
