Author Topic: USD support  (Read 955039 times)
Andrei
USD support
« on: December 01, 2023, 12:11:41 pm »
Hello!
I have trees done in Houdini and saved in USD format, I load them in 3ds max, via VrayScene. It's render as expected, then I scatter them using ForestPack and rendernot correct. It's render it like viewport preview in vrayscene. if I change viewport preview to full mesh in vray scene, it's start render normal  . But after a few changes of mode, it's starts glitching, and it's render previous viewport mode, not currently chosen, after each changing mode, i stop and start again render
Re: USD support
« Reply #1 on: December 01, 2023, 01:27:08 pm »
Hello Andrei,
Thanks for getting in touch, sorry to hear you are having trouble with USD. I'm doing some tests with simple geometry here and so far it's OK. Would you be able to send us a basic scene that reproduces the problem? You can send it to helpdesk@itoosoft.com so you don't have to share it publicly. Also, if you could let us know the versions of Max, FP and V-Ray you are using that would be great.
Many thanks,
