Author Topic: Need to Stripe Grass (Mowing Lines)  (Read 6770 times)
LB1651
« on: August 20, 2018, 08:57:22 pm »
I've found the following tutorial (https://www.youtube.com/watch?v=cUIBzd2NOqY) and it works, but it makes the grass surface very bumpy and irregular.
I need to figure out a way to create stripes in the color of the grass without adding the bumpiness to the grass surface (essentially just a gradient overlay that sits on top of the forest distribution). Any ideas on how to do this?
Thanks!
« Last Edit: August 20, 2018, 09:10:52 pm by LB1651 »
Re: Need to Stripe Grass (Mowing Lines)
« Reply #1 on: August 21, 2018, 09:10:58 am »
There is a Forest Color map for this. Use As texture on surface mode. Documentation reference
LB1651
« Reply #2 on: August 22, 2018, 06:19:02 pm »
Hey Rokas, thanks for the response.  Looking at the documentation, this is exactly what I need.  I don't fully understand how to implement the stripes though.  Where do I need to put the ForestColor Map for this to work?  Do I still need to create the Gradient Ramp within the ForestColor or should I be looking for some sort of preset?
EDIT:  I've attached images of the grass in the viewport and the same grass in a render.  It looks like it should work in the viewport, but the render keeps coming out without the variation.
« Last Edit: August 22, 2018, 06:38:32 pm by LB1651 »
FC1888
« Reply #3 on: August 23, 2018, 02:19:34 am »
Try selecting "get color from map" not using it as a texture
« Reply #4 on: August 23, 2018, 08:59:55 am »
Please attach Your file and we will help You in Your situation.
LB1651
« Reply #5 on: August 28, 2019, 05:55:46 pm »
Wanted to revive this topic and attach the test file as well as the precedent image.  I still haven't figured out how to make the Forest Color method work to achieve the desired result and I'm still not satisfied with the result I'm getting from using a Gradient Ramp in the X/Y Rotation in the Transform rollout.
I think that Forest Color is the solution, I'm just not sure what to do to get the results in place.
Thanks!
Link to 3ds Test File:  https://we.tl/t-MQyqQwkMD2
« Reply #6 on: August 29, 2019, 08:17:26 am »
maybe this technique could help You in this case.
LB1651
« Reply #7 on: August 29, 2019, 03:27:53 pm »
I get an error when I visit that page.  Maybe a broken link?
LB1651
« Reply #8 on: August 29, 2019, 06:32:22 pm »
Weird.  It says "An Error Has Occured: The topic or board you are looking for appears to be either missing or off limits to you."
Same as the first link you posted.
« Reply #9 on: August 29, 2019, 08:48:55 pm »
The only way I can see to do this at the moment that works with V-Ray RT is to use Planar from World XYZ mapping coordinate system. I prefer to use real world map size and then in that way you can easily position the texture using the bitmap map's Size and Offset parameters.
To see the results in the viewports you will probably need to turn on Display Realistic materials with Maps but to help get an approximate position I also find the the Surface's X position minus half its X size gives me a good starting point for the Width > Offset value, and a Y Position minus half the surfaces's Y Size works for the Height > Offset.
Many thanks!
« Last Edit: August 30, 2019, 08:48:27 am by Rokas »
amitgedia
« Reply #10 on: August 30, 2019, 08:26:34 am »
Yes i too get the same error when i visit  the page and also the image that Rokas has attached has a broken link too cant view the image as well
« Reply #11 on: August 30, 2019, 08:48:40 am »
apologies for that.
fixed the text and link, hopefully.
amitgedia
« Reply #12 on: August 31, 2019, 10:36:45 am »
The image that you shared opened fine but the link is not yet fixed still says the same error has occured when you try to open the page
« Reply #13 on: September 01, 2019, 10:43:27 am »
ignore that link. I have pasted it's text in this thread. see this post
