Author Topic: Is it possible to have one 'species' per surface?  (Read 6121 times)
BI1654
« on: March 11, 2014, 11:16:21 am »
Im using forest to scatter a selection of plants in many different trays/pots
But each tray can only have one species, is this possible?
Hopefully I dont need a separate Forest for each one !
Re: Is it possible to have one 'species' per surface?
« Reply #1 on: March 11, 2014, 12:14:09 pm »
You can choose for any distribution area just models you want to use instead scattering all of them.
By default Forest Pack is using all models you have in Geometry tab with corresponding Probability. But if you go under Areas tab to Plants - check Select models and in Pick window you can choose which models will be used for scattering in selected area.
Please check attached screenshots ...
Hope this help you ;)
« Last Edit: March 11, 2014, 12:26:11 pm by Michal Karmazín »
BI1654
« Reply #2 on: March 11, 2014, 12:26:53 pm »
Perfect thankyou
CQ4419
    • GC STudio, Paris
« Reply #3 on: March 11, 2014, 01:44:11 pm »
Very very helpful thank you ! What a wonderful product !
BI1654
« Reply #4 on: March 11, 2014, 04:33:10 pm »
Is there any way to randomize this process by the way?
Now I have 708 different areas/surfaces and I sure as hell dont want to manually assign the plants for each one :)
« Reply #5 on: March 11, 2014, 07:08:54 pm »
There are many ways how to get the result you want.
In your case I´ll attach all areas to one object. Then using Selection - By Random detach the selection in to the unique object / distribution area. You should aim to have the same number of object as vegetation species. Then assign each type of vegetation to this newly created areas.
Hope it´ll help you.
