Author Topic: Issue with open spline  (Read 101785 times)
Nildo Essa
« on: January 11, 2007, 07:16:07 pm »
Im having a problem, with distributing forest with an open spline...im making an animation of a soccer game, and i have to fill th stadium with ppl, they are not to be animated, but i thought that maybe i would get less work if i drew several splines along the seats and attach them together...this way i would just pick the spline (with multiple splines on it, as they are attached), and the planes would fit them!...it works except that the planes stay only on one level...in this case aligned with the top spline...how can i get the planes to fit the splines on diferent levels without having to make a forest object per row of seats???
thx!
Nil
Re: Issue with open spline
« Reply #1 on: January 11, 2007, 08:10:43 pm »
Hi Nil,
I've done some tests, but unfortunately there is not an easy solution. Forest is designed to be linked with a surface object to get the Z positions, so by default, it uses only the height of the first spline. Anyway, i must check the source code... perhaps we may do some changes for the next release to support multiple splines.
By now, you must use several Forest objects or attach it to a dummy surface.
