Author Topic: Item editor bug with 9.2.0 release?  (Read 31963 times)
DM5847
« on: April 28, 2025, 01:49:01 pm »
We've run into an issue since installing the 9.2.0 release last week. When placing plants/trees we often use the item editor.
However when adding objects set to "randomise" it will no longer randomise the objects (we get just a single objects repeatedly placed) and also they only follow a single transform setting (translation - rotation - scale). As you can see from the screenshot we have a box and cylinder to place and have set the transform to randomise min-max settings. But all the objects are placed the same way.
We just installed 9.2.1 but that didn't fix it. Installing 9.1.9 did.
Are we missing something in the settings that has been introduced or is it a bug?
Vray (newest version of ) 6
Max2023
Re: Item editor bug with 9.2.0 release?
« Reply #1 on: April 28, 2025, 02:36:12 pm »
I'm sorry to hear you're experiencing these issues. I can confirm there is a problem when adding new items via the Custom Edit mode in versions 9.2.0/9.2.1. Our main developers will investigate it further. Thank you very much for your feedback — it’s important to us. On behalf of the entire team, I sincerely apologize for the inconvenience.
DM5847
« Reply #2 on: April 28, 2025, 04:12:23 pm »
Good to know it's not on our side. We'll roll back to 9.1.9 for now then. Thanks.
frencha87
« Reply #3 on: May 02, 2025, 04:56:49 pm »
Our team is also experiencing the same bug, looks like it's still happening in version 9.2.1 as well
KU4355
« Reply #4 on: May 03, 2025, 08:25:56 am »
same here.
« Reply #5 on: May 05, 2025, 09:26:38 am »
We'll release an update soon.
Meanwhile, you can select the affected items and use Items Editor->Properties->Randomize.
« Reply #6 on: May 06, 2025, 10:31:08 am »
