Author Topic: Itooforest dissappears when rotating surface  (Read 6136 times)
BJ2366
« on: July 05, 2017, 05:49:18 pm »
Hello there, I purchased a maxtree file with multiple forest objects to create a green wall.
When I rotate the surface  the forests object either reduce or completely disappears (rotation 90°)
The forests objects are on xy mode and auto is seleted.
Thanks for your help
Alex
Re: Itooforest dissappears when rotating surface
« Reply #1 on: July 06, 2017, 09:51:10 am »
Hi Alex,
When using the XY mode (items are distributed using the XY plane of the Forest object (in local coordinates), and then placed on the surface moving each object along its Z axis), you should bind the Forest object & the surface with the 3ds Max's Select and Link tool.
Please feel free to check our "Scattering on Vertical Surfaces" tutorial, where you can find several useful tips regarding this topic.
BJ2366
« Reply #2 on: July 06, 2017, 04:12:01 pm »
hello Michael,
thanks so much for your reply that seems to work just fine.
I did look at the tutorial for further help, i.e. clusters etc... it was really helpful.
Thanks again it is really appreciated.
Alex
