Forest Pack => Forest Pro (*) => Topic started by: ES1947 on July 15, 2014, 12:54:43 pm
Title: Just installed for 3ds max design 2015 - dll error
Post by: ES1947 on July 15, 2014, 12:54:43 pm
Just downloaded ForestPackPro424 and selected C:\Program Files\Autodesk\3ds Max Design 2015\ as path, but when I start 3ds max design 2015, I get the attached error.
Has anyone a solution for this?
Title: Re: Just installed for 3ds max design 2015 - dll error
Post by: Michal Karmazín on July 15, 2014, 01:22:22 pm
It looks like 3ds Max can't find some of libraries used by the plug-in. As all of them are part of 3ds Max they shouldn't be missing, but please try to install the Visual C++ Redistributable for Visual Studio 2012 Update 4 (http://www.microsoft.com/en-US/download/details.aspx?id=30679). Please tell us if that solves the issue. Thanks in advance.
Kind regards,
Post by: ES1947 on July 15, 2014, 01:28:00 pm
Hi Michal
I just downloaded the file. I get the attached message.
I'm not sure if I should use the repair function?
Post by: ES1947 on July 15, 2014, 01:43:18 pm
Well tried to use the repair function - still get the error.
Post by: Michal Karmazín on July 15, 2014, 01:48:57 pm
Yes, please use the Repair option. If the problem persist, please take a screenshot of <maxdir>\plugins\ForestPackPro.dlo file Properties. Just to double check, that the correct file was placed into plugins foder. Thanks in advance.
Kind regards,
Post by: ES1947 on July 15, 2014, 01:54:11 pm
Screenshot
Post by: iToo on July 15, 2014, 03:45:02 pm
It seems the file ForestPackPro.dlo is not correct. It matches with the dlo of Forest Pro 4.1.5 for Max 2014.
Please, try this:
1.- Close Max.
2.- Remove the file ForestPackPro.dlo.
3.- Reinstall Forest.
That should solve the problem.
Post by: ES1947 on July 15, 2014, 04:05:49 pm
Hi Carlos
A reinstall seemed to fix the problem.
