Forest Pack => Forest Pro (*) => Topic started by: TQ2169 on November 03, 2022, 08:50:13 pm
Just updated to the new Forest Pack and the falloff areas isn't working as previous.
When adding a falloff (global props) and creating an exclude, the scatter objects just disapear.
The option to scale isn't changing the objets scale either.
Also when checking the boundary Checking and selecting the Point/edge/size the forest doesn't change at all...
Could you please verify these issues.
Thanks in advance.
Thanks for reporting this issue. It would appear to be an issue that only affects rectilinear splines. We're working on a fix!
Best,
Dear Paul,
Thank you for your reply.
Actually it was affecting all forests that were generated on surfaces.
Needed to rollback to an old version as I use the area options a lot.
All options in this rollout aren’t working as they should.
Also would like to mention that in the area options, exclude by size/edge/point display the same objects.
Not similar to what the latest versions were doing.
Best regards
João
Thanks, we have a fix here already that appears to be working OK. We'll release a patch soon.
Great! Do you have an ETA on the patch?
Fixed in Forest Pack 8.0.5 (https://forum.itoosoft.com/announcements/forest-pack-litepro-8-0-5/).
Perfect!
Gonna update ASAP.
All the best,
João
