Forest Pack => Forest Pro (*) => Topic started by: KQ8229 on January 12, 2018, 08:26:17 pm
I've made a simple animation where I'm moving through an apartment. Here the carpet flicker incredibly much, and there are also a lot of white sparks in the carpet.
I've also tried a simple animation with grass and meadow, and it's the same result.
Is there anything special I need to be aware of when I make animation with the front pack?
https://vimeo.com/250862912
password: carpet
Unfortunately, there is not a simple way to eliminate all noise / flickering, since it depends on the render engine and it may have multiple causes (GI, AA sampling,...). Please feel free to take a look at the following link. It includes useful information regarding this topic and some tricks:
http://forum.itoosoft.com/index.php?topic=905.0
In case you're using the V-Ray renderer, I would suggest you check / ask on the ChaosGroup forum. Many of their members are experienced users of Forest Pack, and they can suggest you other useful settings.
Hope that helps a bit.
Has anyone made some vray.cfg files that work with itoo forest that prevent flickering?
Doesn't seem like a difficult aid itoo could provide.
thanks for considering
Regarding render settings it is always speed vs quality.
I like vray universal (https://docs.chaosgroup.com/display/VRAY3MAX/Universal+V-Ray+Settings) settings as a good starting point.
