Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Layered panel scatter problem
« previous
next »
Print
Pages: [
1
Author
Topic: Layered panel scatter problem (Read 3185 times)
Mike123
Newbie
on:
November 13, 2021, 01:34:02 pm »
I got a strange problem today while I thought it should be very easy - but I don't know what is wrong with me.
Pls find attached - I can't scatter the small box on every panel.What make this happened?
Logged
ITOOSOFT
Hero Member
Re: Layered panel scatter problem
Reply #1 on:
November 15, 2021, 09:45:55 am »
THanks for the scene. A single surface in XY mode will scatter on the topmost face. To scatter on all layers you can change the mode to UV.
A limitation of UV mode is that the distribution is the same for each layer, but you can get around this by changing the surface's UVs so that each layer occupies a different UV space.
I hope that helps,
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
