Author Topic: Select objects in the scene that are used in Forest Pro  (Read 4760 times)
JI2645
« on: January 14, 2021, 01:52:51 pm »
Hello there,
I need to select all the objects that a selected Forest Pro uses in Geometry tab.
I tried to search for answer before posting here with no success. Apologies if I missed it
Thank you!
Svetlin
« Last Edit: January 14, 2021, 02:05:03 pm by JI2645 »
Re: Select objects in the scene that are used in Forest Pro
« Reply #1 on: January 14, 2021, 02:47:01 pm »
There is a quad menu option to select dependencies- geometry/surface/area:
Anyway it currently does not allow to select all geometry dependencies. You can do that with little helper tool Forest Pack Toolbox:
« Last Edit: January 14, 2021, 02:57:36 pm by Rokas »
JI2645
« Reply #2 on: January 14, 2021, 03:40:58 pm »
This is amazing :-)
Thank you very much!
Neto
« Reply #3 on: May 31, 2023, 04:22:47 am »
how to activate in quad menu???Thanks!!!!
« Reply #4 on: May 31, 2023, 10:51:44 am »
Please try manually executing the forestpack.ms located under C:\ProgramData\Autodesk\ApplicationPlugins\ForestPackPro2024\Contents\scripts\startup by using Scripting > Run Script... to see if that helps.
