Author Topic: Number of materials is FP object  (Read 3035 times)
CO2158
« on: January 26, 2022, 02:28:43 pm »
Hi, is there a max number of materials - multimaterials to have in a FP object? I am trying to create an FP object (the geometry nodes have many many submaterials) and it keeps messing the materials. Thanks
Re: Number of materials is FP object
« Reply #1 on: January 27, 2022, 03:56:57 pm »
Thanks for the message. Which version of Forest Pack and which renderer are you using? In recent releases, we no longer use the multi-sub material generated by Forest Pack for final renders. Instead the material on the source geometry is used directly and the multi-sub material only for viewport previews and in case of needing to support legacy versions of renderers.
In any case, the limit for multi-sub objects is 999 materials. This is a limitation of Max that I am afraid we cannot circumvent.
I hope that helps,
