Author Topic: Library browser staying on top of scale messages  (Read 2682 times)
Max Daiber
« on: February 27, 2019, 12:11:28 am »
Hi!
I have been getting this issue lately where the library browser is getting on top of the scale message asking to convert the units of imported objects from the browser itself. This happens if I miss to click inside the message, and then I can't reach it.
This is very annoying as it makes it really important to click inside the message box or otherwise you can't save or anything.
If anyone has some solution to this I would be thankfull!
Re: Library browser staying on top of scale messages
« Reply #1 on: March 01, 2019, 03:21:58 pm »
Well, the XRef Object Merge Units Mismatch window should be always on the top. Would you mind to specify your actual software configuration (OS, 3ds Max, FP & renderer versions used)?
Thanks in advance for any further comments on this issue you can share with us.
