Author Topic: Unable to drive scale change with map channel  (Read 5790 times)
UF2498
« on: April 16, 2018, 07:44:24 pm »
Pretty much what the title says. I run FP 5.2.0 on 3ds max 2016. I can drive scale changes with procedural maps like noise etc, but scale in a controlled way using textures and UV's. See attached.
UF2498
Re: Unable to drive scale change with map channel
« Reply #1 on: April 16, 2018, 07:46:16 pm »
Oh and yes... If I change the map to object based XYZ - then something happens, but it seems unpredictable.
« Reply #2 on: April 17, 2018, 10:48:31 am »
It is working in my test:
Could You please attach Your scene?
« Last Edit: April 18, 2018, 08:22:53 am by Rokas »
UF2498
« Reply #3 on: April 17, 2018, 04:37:01 pm »
Thanks, here goes.
« Reply #4 on: April 18, 2018, 08:22:28 am »
Hi, thanks for file.
The only thing You need to do is to add Your surface to a Surface rollout:
UF2498
« Reply #5 on: April 19, 2018, 06:13:48 am »
Face palm! Mea Culpa. Many thanks!
