Author Topic: Path distr. Z offset  (Read 10212 times)
RealViz
    • RealViz
« on: April 24, 2025, 11:43:18 am »
Hi, if Path Distribution is used and Z Offset is set for objects, then it will switch to CustomEdit. This Z-Offset is ignored and the objects are shifted. Would it be possible to fix this? Thank you.
Re: Path distr. Z offset
« Reply #1 on: April 24, 2025, 12:19:15 pm »
Thanks so much for reporting it. I was able to reproduce the issue on my end as well. Our development team will take a closer look. In the meantime, you can manually adjust the Pivot Point of these items along the Z-axis to avoid the unwanted behavior.
RealViz
    • RealViz
« Reply #2 on: April 25, 2025, 10:55:51 am »
Thanks! For me the solution was very simple this time, it was mainly a bug-report.
