Author Topic: Translation distribution map  (Read 21868 times)
djibvongenf
« on: July 19, 2024, 07:39:21 pm »
Hi all,
Im trying to achieve an effect with the translation rollout to get a "wave" (white curve in the screenshot) distribution of an object in an area.  But i can't find any tutorials about this effects.
I've tried a probability map (b/w radial gradiant) plugged in with no result.
Maybe someone would have a clue.
Thank you
Re: Translation distribution map
« Reply #1 on: July 22, 2024, 09:17:37 am »
Adjusting the Min and Max values as needed will do the trick. Please find attached a sample scene (240722_TranslationMapSampleScene_iToo.max). Additionally, please note that the Probability Map is designed for a different purpose. As mentioned in our documentation: 'Scatter objects in black areas of the map will not be randomized; objects in white areas will receive a value selected from the full range.'
I hope this helps.
