Author Topic: Light Instances not visible in Viewport  (Read 1438 times)
« on: December 11, 2025, 09:26:15 am »
I haven't used FP in a while. I noticed that the light instances don't show up in the viewport unless an FP Object is selected. Is this normal?
Re: Light Instances not visible in Viewport
« Reply #1 on: December 11, 2025, 09:59:24 am »
No, it's not normal. We used some tricks to draw lights using their native geometry, but it seems that causes problems in latest Max versions.
Please, use the Display->Proxy mode. That draws light instances as a marker dot.
If we cannot fix it, probably we'll remove that drawing method in next updates, to avoid problems.
« Reply #2 on: December 11, 2025, 10:14:47 am »
Yes, I noticed that proxy converts to a dot.
Ok. I'll use some geometry (Cone, Pyramid) in a Group with a Light Source to display.
Thank you.
OM2863
« Reply #3 on: December 19, 2025, 04:49:43 pm »
Hello, we recently started using FP to instance lights in our scene files. It was very convenient to actually see the lights. Any chance of bringing back the ability to display the lights? Maybe adding a new toggle option and popup warning regarding issues with nitrous. Thanks!
« Reply #4 on: December 20, 2025, 08:57:34 am »
Hi, unfortunately it's not possible. Not only lights are not properly displayed, but we also noticed that Max crashes sometimes.
