Author Topic: limit height  (Read 3133 times)
HG3914
limit height
« on: June 16, 2021, 01:05:14 pm »
I have this problem, hope to get some help .
A- is the terrain
B - wall limit
In green vegetation.
I want to distribute trees along the terrain but only until get the top of the wall , so i want to limit the height.
Any suggestions?
https://ibb.co/c1CjsgM   - link to illustrate image
Re: limit height
« Reply #1 on: June 16, 2021, 01:36:21 pm »
Hi.
ForestPack Surface rollout has Altitude Range settings.
You can adjust distribution and exclude points above some threshold.
It calculates by bottom plant position, not top, but if foliage is of approximately the same size it will be fine. Example:
FC1888
Re: limit height
« Reply #2 on: June 16, 2021, 03:55:35 pm »
Difficult to understand, what exactly you are asking.. If all you need to do, if you want all vegetation to stay below the height of the wall, surely you would just use the scale transform. If your vegetation model, is higher then the wall, you just scale it down, so that it's upper Z scale value is at or below the height of the wall.
Perhaps you could have rendered a simple 3D view, showing the terrain and the wall, then mark that up to show what it is you want to achieve
