Author Topic: Limit visibility - how to fool reflections?  (Read 7277 times)
GF1991
« on: March 04, 2012, 03:33:46 pm »
Hi guys,
when one uses limit visibility option its impossible to see scattered objects in the reflection because...obviously...behind the cam, there is nothing scattering.
Is there a way how to fool this while having limit visibility on???
Hope the question is clear enough :))))
Thanks for reply
Best
Martin
Re: Limit visibility - how to fool reflections?
« Reply #1 on: March 04, 2012, 03:58:48 pm »
No, unfortunately it's not possible. If that helps, you would increase the "Back offset" parameter, to get more items behind the camera.
NP2090
  • Guest
« Reply #2 on: March 05, 2012, 11:05:22 pm »
What about making another forest Limited to a second camera that is facing backwards.
If its an animated camera then you have a more challenging time of reflecting the Main cameras motion
off the top of my head you could duplicate your original camera and link it to a dummy that is at the centre of your reflecting object (and rotated to match).. link a new camera (the one that is limiting you reflection forest) the the duplicated main camera, then scale the controlling dummy in a way that mirrors you MAIN camera.
Its a bit convoluted though, so personally, i would use a reflection card that has a texture on it.. maybe put a few hero objest in front of it, if you really need some parallax shift.
If it works, the easiest way is definitely adjust the back offset, like mentioned above.
happy hunting!
« Last Edit: March 05, 2012, 11:07:22 pm by That 3d Guy »
« Reply #3 on: March 06, 2012, 08:39:18 am »
We have some ideas to improve the camera clipping, working well with back reflections. Probably we will work on this for next Forest versions.
barry john
  • Barry John
    • 3d digital studio
« Reply #4 on: November 11, 2013, 09:14:44 pm »
just wondering if there is update on this post, wondering how to get reflection?
« Reply #5 on: November 12, 2013, 08:38:58 am »
Sorry, no changes in the software regarding this issue. Some of the the ideas i had were not possible, because technical limitations.
You may increase Camera->Expand and  Back Offset to open the camera's frustrum. If that doesn't work, you should disable completely camera clipping.
