Author Topic: new FP7 - having trouble with it  (Read 30116 times)
Re: new FP7 - having trouble with it
« Reply #15 on: April 09, 2021, 09:45:36 am »
I apologize for that. We had to remove Custom Edit mode from the Creation panel, because technical incompatibilities with new the features. That was causing crashes and other issues.
There are certain restrictions about what can be done while an object is being created. Instead, there are not restrictions from the Modify tab, because the FP object is already initialized.
KQ8229
« Reply #16 on: April 27, 2024, 11:54:45 pm »
Ok so before I could just generate multiple trees at specifik places where I click the mouse and then pick objekt in library. Wery easy.
Now I have to:
Place icon - go to geometry - pick objekt in library - Go to item editor - Custom the tree - click yes - go to add item - start clicking the places I want a tree.....
I would like the software to be more efficient not less..
PLEASE itoo. Bring back "custom edit" under the "Forest creation" panel. I still use FP6 due to this bad "upgrade" removing this easy tree placing method. And therefore I'm stuck with max 2018 because your FP6 doesn't work with newer max....
« Reply #17 on: April 28, 2024, 09:52:16 am »
I'm sorry, but it's not possible.
We have introduced many changes since FP6, and this creation method was causing problems with FP7. Now we are going to release FP9, which is even more different.
