Author Topic: Trees not render in "automatic" mode.  (Read 7610 times)
Alexey Kuznetsov
« on: September 04, 2012, 11:27:17 am »
Trees rendered only in "meshes" mode. In "automatic" mode not rendered, but if you use the "isolate selection", render in "automatic" mode without problem.
Re: Trees not render in "automatic" mode.
« Reply #1 on: September 04, 2012, 12:12:23 pm »
Is the same scene of the other post ? If not, please upload it.
Alexey Kuznetsov
« Reply #2 on: September 04, 2012, 12:23:24 pm »
No, it not test scene. It scene is very big (~ 600 mb, 32000000 poly) plus 2 Gb textures. For probe I delete all forest in scene, but one, yet not solve the problem.
Alexey Kuznetsov
« Reply #3 on: September 04, 2012, 12:46:01 pm »
Reducing the number of trees is not a solution, trees rendered only in "isolate selection".
« Reply #4 on: September 04, 2012, 01:22:15 pm »
Reducing the number of trees should not be necessary. Does "Forest Stats" show some warning message ? (check it in the General rollout)
Please, try to reproduce the problem in a separate scene containing only the Forest objects. In this case, should be easier to send us the file.
Unfortunately in most of cases we must check the scene to find the problem.
Alexey Kuznetsov
« Reply #5 on: September 05, 2012, 12:54:50 pm »
I found the source of the problem. The forest is not render, if the scene a lot of instant objects. I multiplied their FPP and it worked.
« Last Edit: September 05, 2012, 12:56:59 pm by Alexey Kuznetsov »
« Reply #6 on: September 05, 2012, 01:04:20 pm »
Ok, i'm glad the problem is solved.
Alexey Kuznetsov
« Reply #7 on: September 05, 2012, 01:09:08 pm »
FPP - super! Knowingly I did not clone objects with it before, lost a lot of time. Many thanks for such a great software!
