Author Topic: Safety measure when adding surfaces  (Read 8096 times)
DT
« on: November 09, 2022, 05:47:10 pm »
Would it maybe be possible to have some sort of safety measure built in for when applying a surface to a FP object. For instance I tried to add a surface but I clicked just a little bit wrong in my model and clicked on a complex building instead. Result is Max completely frozen and unresponsive.
RealViz
    • RealViz
Re: Safety measure when adding surfaces
« Reply #1 on: November 10, 2022, 10:08:50 am »
I have been using FP for years and have never had a problem with adding surface. I think for more complex scenes, select by name (attachment) is sufficient. Or always select surface + given FP and issolate. After then assign the object.
« Reply #2 on: November 10, 2022, 10:18:22 am »
I don't see what rule we could use for that. From the plugin side, a building or a surface is just a mesh with many faces.
As RealViz suggested, in these cases the best option is to assign by name.
DT
« Reply #3 on: November 10, 2022, 11:55:36 am »
Hi, thank you for the response, I was also thinking about that. Maybe when a surface consist of more than X amount of elements, there could be a warning. Because it's weird: why FP would make Max not responsive in this case. The geometry might be 'complex (consisting of multiple elements) but the total surface area is a smaller than most surfaces I use to scatter grasses or anything. So there shouldn't be that many items. Not sure why it would make Max hang.
As for RealViz's tip, I isolate most of the time before assigning instead of the assign by name option. I don't have this a lot, might have been the 5th time in 10 years. I was just wondering why it would hang Max and if this could be prevented.
