Author Topic: Scattering over multiple surfaces not working when using effects  (Read 2594 times)
SE7479
I'm trying to scatter office furniture over multiple floors. Everything works fine until I add the Z_Rotate_Step effect. As soon as I do this, it will only scatter on the very top plane. I've tried it in a new scene with just boxes and the outcome is the same.
Any ideas?
I'm using 3ds max 2016 sp3 and FP 5.1.0
Many thanks,
Chris
Re: Scattering over multiple surfaces not working when using effects
« Reply #1 on: August 24, 2016, 11:42:12 am »
Thanks for reporting this issue on stacked surfaces. We'll see what can be done to avoid such unwanted behaviour.
Meanwhile, I would suggest you to use the UV mode or the Probability Curves feature. Also I would suggest you to check our "Populate Building Interiors" tutorial covering this topic in detail. Hope you'll find it interesting and helpful.
SE7479
« Reply #2 on: August 24, 2016, 12:05:05 pm »
Hi Michal,
Thanks for the workaround, I'll use one of those for the time being.
Cheers,
Chris
