Author Topic: mask for multiple surfaces object  (Read 88 times)
Pierre
    • Studiosezz
« on: November 10, 2025, 09:45:33 am »
I am currently using iToo Forest 9.3.2 with 3ds Max 2026.2.
I would like to distribute grass across two separate mesh objects (rocks), with each object utilizing a different mask for distribution. I am wondering if it is possible to achieve this using a single Forest Pack object, or if it requires creating two separate Forest Pack ?
Thank you for your help.
Pierre
Studiosezz PARIS
www.studiosezz.com
Re: mask for multiple surfaces object
« Reply #1 on: November 10, 2025, 09:59:29 am »
Hi Pierre,
Although there’s only one Surface Area, you can disable it and add two Spline Areas to cover those surfaces instead. This way, you can adjust the Distribution Map settings individually for each of them.
I hope this helps.
Pierre
    • Studiosezz
« Reply #2 on: November 10, 2025, 10:17:29 am »
Thank you for your reply Michal
Unforntunatly my meshes are overlapping in places. With the method you described, is it possible to limit the distribution of a mask to a specific mesh, perhaps by using an ID?
Studiosezz PARIS
www.studiosezz.com
« Reply #3 on: November 10, 2025, 10:49:16 am »
Yes, for these purposes, you can use the Surf. Mat. ID field, which allows you to include only the listed Material ID(s).
