Forest Pack => Forest Pro (*) => Topic started by: FU1583 on January 09, 2023, 09:08:58 pm
Title: material not is assigned with custom geometry
Post by: FU1583 on January 09, 2023, 09:08:58 pm
hello, as the subject says, after the last update that I made (8.0.6), I have not observed that the materials are assigned as it was done in other versions, here is the capture of a newly assembled forest.
Title: Re: material not is assigned with custom geometry
Post by: Michal Karmazín on January 10, 2023, 08:38:41 am
Which renderer are you using? Since the FP7, V-Ray now uses the materials assigned to each Custom Object, instead of the “auto-material”.
I hope that clears it up and in case of any further question(s) or doubt(s), please don't hesitate to contact us. Have a nice day.
Post by: FU1583 on January 10, 2023, 01:23:41 pm
Hello, thank you very much for the answer. I am precisely using Vray in my scene. It seemed strange to me that it started to happen with version 8, but I see that it is ok.
So, now to modify some vegetation material, I have to do it directly in the source object, is this correct?
Post by: Michal Karmazín on January 10, 2023, 02:33:21 pm
Exactly. You should modify directly the material assigned to the used Custom Object(s).
