Author Topic: Problem when merging a file from xrefs  (Read 7808 times)
QD6218
« on: March 20, 2024, 06:48:15 pm »
Hello I'm having a trouble when I merge a file from the xref window, all the scales of my forest pack assets come with the wrong scale
CharlyRT
Re: Problem when merging a file from xrefs
« Reply #1 on: March 21, 2024, 12:11:18 am »
When you merge a object as xref this is included as XrefScene, when selecting with ForestPack it includes the Dummy instead the geometry
have you tried to use xref object instead?
« Reply #2 on: March 21, 2024, 08:46:01 am »
Enabling the Respect System Units in Files option in the System Unit Setup window & marking the Rescale the XRef Objects to the System Unit Scale checkbox during the Create XRef Record from File process should do the job (when using any geometry from a scene with a different Scene Unit Setup, it will rescale the geometry accordingly). I hope that helps.
