Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Use Animation from Custom Object
« previous
next »
Print
Pages: [
1
Author
Topic: Use Animation from Custom Object (Read 8187 times)
RB4467
Newbie
on:
August 16, 2011, 10:48:24 am »
Is there a way to use the animation of an animated custom object?
If so it would be great to use so custom random offset for it to. So you could grow different Buildings/trees etc. randomly.
Thx in advance
Logged
Administrator
Hero Member
Re: Use Animation from Custom Object
Reply #1 on:
August 16, 2011, 11:01:20 am »
Yes, you can assign animated objects or proxies directly to Forest. The animation properties, including random offsets are defined here:
http://itoosoft.com/forestpack/reference/refanimation.php
Logged
RB4467
Newbie
Reply #2 on:
August 16, 2011, 02:25:58 pm »
Thx for the fast response. I'm trying to use an animation of a scaled building/tree (from frame 0 = scale 0 to frame 20 = scale 100). But it seems that nothing is happening. I don't know what I'm doing wrong.
Logged
Administrator
Hero Member
Reply #3 on:
August 16, 2011, 04:44:23 pm »
Does it work with a test scene ? What are your settings in the Forest animation parameters ?
If you can send us the file, we will take a look to it.
Logged
RB4467
Newbie
Reply #4 on:
August 17, 2011, 09:26:01 am »
No, sadly it doesn't even work with a test scene. It seems that Forrest doesn't recognize a scaleanimation. But it worked with a workaround. Ive tried to use a modifier (because of the tutorial you send me). So I've used a simple FFD and animated it. And now it works.
Last Edit: August 17, 2011, 09:46:28 am by RB4467
Logged
Administrator
Hero Member
Reply #5 on:
August 17, 2011, 06:32:51 pm »
Yes, you must apply some modification to the geometry. The changes on position, rotation and scale are not recognized because some limitations in the mode that Max handle them.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
