Author Topic: wind grass sine wave  (Read 3853 times)
in3des
« on: February 24, 2020, 09:21:38 am »
I'm trying to get wind effect on the grass.
Getting some issues when following this topic https://forum.itoosoft.com/forest-pro-(*)/how-does-rotation-by-texture-really-works
I can see results from RED color and GREEN.
But it looks like BLUE color has no effect. (((
« Last Edit: February 24, 2020, 09:28:01 am by in3des »
in3des
Re: wind grass sine wave
« Reply #1 on: February 24, 2020, 09:26:34 am »
I could get some result with green color - but need same with blue
my grass instance is already bent and I need to rotate it along Z axes only
ideally I need
Z - sine wave +-some variation
XY - some variation
in3des
« Reply #2 on: February 24, 2020, 10:05:16 am »
Not sure if that possible - would be great to have direction control by spline/splines.
So you could just draw a spline and forest would arrange its objects along that spline.
« Reply #3 on: February 24, 2020, 10:22:29 am »
Are You after this effect:
in3des
« Reply #4 on: February 24, 2020, 10:41:01 am »
Hi Rokas,
Thanks for reply!
I just found out - the issue was I didn't check the box to use "map" on Z axys )))
now everything looks fine! :)
in3des
« Reply #5 on: February 24, 2020, 10:44:52 am »
Any advice how to add random variation on top of rotation set by map?
so it follows sine wave +-5 degrees on Z (kind of noise)
« Reply #6 on: February 24, 2020, 10:54:56 am »
Under color, there is noise parameters, that can be used for that:
Or You can use additional effect (attached):
« Last Edit: February 24, 2020, 12:09:31 pm by Rokas »
in3des
« Reply #7 on: February 24, 2020, 12:17:42 pm »
Cool!
Thanks a lot for help! :)
