Author Topic: randomise vary by spline  (Read 6467 times)
gnu
« on: August 05, 2011, 04:08:29 pm »
so, you have clumping and distribution by rgb map.  hows about being able to use different species in each closed spline. this would make doing fields of different crops within one forest object very easy.. if it were possible to have a lister (like you do for plant types)  and add multiple splines, you could even use the wireframe colour of the spline like you do with the rgb map, picking the plant that is closest to the wire colour.
Re: randomise vary by spline
« Reply #1 on: August 05, 2011, 06:34:20 pm »
We have plans to modify the areas rollout. I add your suggestion to the wishlist.
Ideally each area should include several plant types, although this is much more difficult to implement... well, we must think on it.
