Forest Pack => Forest Pro (*) => Topic started by: TE4467 on April 13, 2014, 01:04:23 am
Title: Mesh Renders but does NOT display
Post by: TE4467 on April 13, 2014, 01:04:23 am
I have tweaked the FPP Tree (removed some leaves) and re-added it as a new library object.  The point cloud displays fine and renders fine.  Now I want to collapse these trees to an object.   To do this I understand that you need to have displayed in the VP what you want the collapsed mesh to look like (i.e. display mesh vs point cloud).  However when I tick the radial button for Mesh, nothing shows up.
Alternatively I tried the FPP tools to Instanciate to individual objects but recieved the same results, a blank scene.
Any help is appreciated.
-Greg
Title: Re: Mesh Renders but does NOT display
Post by: iToo on April 13, 2014, 09:22:56 am
Yes, the viewport mode must be in Mesh mode to collapse the object. Does it show some error in General->Forest Stats after setting this mode ?
Anyway, this is not necessary with Forest Tools. It should convert all objects regardless of the viewport mode.
If you cannot fix it, please try to reproduce the problem in a minimal scene and send it to support@itoosoft.com. We'll check it.
