Forest Pack => Forest Pro (*) => Topic started by: EH2026 on September 08, 2023, 01:17:52 pm
Title: Metre unit Problem-How to create realistic grass edges using Forest Effects
Post by: EH2026 on September 08, 2023, 01:17:52 pm
Hi guys,
I have a small problem in that when trying this tutorial on your website...
https://www.itoosoft.com/tutorials/how-to-create-realistic-grass-edges-using-forest-effects?track=mastering-forest-effects
It is restricted to 1 unit being the minimum under effects, 1 unit for me is 1 metre, so trying to do a grass edge of 1 metre doesn't work very well, we really need it down to 10cm but this isn't possible.
Thanks again and any help appreciated.
Jason
Title: Re: Metre unit Problem-How to create realistic grass edges using Forest Effects
Post by: Michal Karmazín on September 08, 2023, 01:27:14 pm
Hi Jason,
You can easily adjust or remove the limit by modifying the effect – by opening the Style Editor and adjusting/disabling Properties > Limits. I hope that helps.
Post by: EH2026 on September 12, 2023, 06:18:18 pm
Fab Michal, that worked a treat, many thanks as always!
Jason
