Author Topic: paint area on stacked surface?  (Read 2663 times)
ritoo
« on: September 08, 2023, 05:53:14 pm »
Is it possible to paint area on multiple floor surface independently?
Re: paint area on stacked surface?
« Reply #1 on: September 11, 2023, 08:36:18 am »
Sure – you should assign different Material IDs to them, add these surfaces to the Surfaces List “individually” and within Paint Area properties use the corresponding Surf Mat ID. That’ll do the trick.
ritoo
« Reply #2 on: September 14, 2023, 09:40:55 am »
Yep it worked, thanks a ton!
