Author Topic: Problem with edge setup  (Read 19864 times)
Notoriousbug
« on: March 08, 2025, 12:52:35 pm »
hello everyone and sorry for my English..I use translator....
I can't understand why with forest the grass doesn't cut correctly on the edges..I tried first one way (image_01), then adding a spline and selecting it with exclude enabled (image_02), it improves a little bit but there are always little clumps of grass that I don't want to have. Can someone maybe tell me where I'm going wrong?
thanks
Not
Re: Problem with edge setup
« Reply #1 on: March 10, 2025, 08:40:59 am »
If possible, send us a simplified version of your scene, and we’ll check it here.
Notoriousbug
« Reply #2 on: March 10, 2025, 10:22:36 am »
hi @Michal Karmazín, very kind.
I just sent to helpdesk@itoosoft.com the simplified file.
thank you
Not
« Reply #3 on: March 10, 2025, 02:57:33 pm »
Replied by email.
Notoriousbug
« Reply #4 on: March 10, 2025, 06:49:56 pm »
thanks to the forest team who solved my problem. I am pasting below the message I received in case it might be helpful to others as well.
" In your setup, you're using a large Spline Area in the Include mode with the surface as a base to 'cut' it - this combination might not be ideal. In the revised version of your scene, I've adjusted the Spline Area to cover just the desired area, which seems to resolve the issue. Also, I've lowered the Transform > Translation values a bit."
Not
