Author Topic: Mulch Planting Areas  (Read 10056 times)
BKE
« on: May 08, 2012, 11:23:56 pm »
Has anyone used Forest Pack Pro to 'paint' mulch planting areas onto a surface? Is this feasable? ???  Advisable?  ???
I can see 'painting' a planting area.. adding mulch to it, then adding the various bushes & flowers. It would be a nice workflow.
Re: Mulch Planting Areas
« Reply #1 on: May 09, 2012, 09:49:13 am »
We have not tried it, but depending of the mulch type probably would be more efficient to use a texture. I note the idea for next sample scenes. ;)
BKE
« Reply #2 on: May 09, 2012, 12:42:19 pm »
Thanks for the response, Carlos. I will keep my eye out for that! If I get a chance to experiment, I will share, too.
Your response sparked a new thought.  :o I really like the Paint/Spline command. Would it be possible to have that painted area define a different texture? In other words: I can have my entire landscape area 'grass', then paint planting areas with Forest Pro, and, within Forest Pro, assign a 'mulch' texture to the painted area.
Thanks again.
« Reply #3 on: May 09, 2012, 01:46:19 pm »
No, it is not possible because Forest doesn't render textures, only items. But you would convert the Paint area to a spline (there is a button in the Area properties for that), and then use it to modify the surface or create a new one with the right material.
BKE
« Reply #4 on: May 09, 2012, 02:33:57 pm »
Thanks again, Carlos. That is a fine solution. I am an Architectural Designer. My main software is REVIT, but I use Max/Vray/Forest Pack more & more these days. I know it is no longer a Forest Pack question, but could you please tell me (a 3ds Max neophyte) how to use the spline that I create in Forest Pack to redefine a surface texture? I have attempted to do this & I have searched the web,etc., but with no success.  :-\
« Reply #5 on: May 09, 2012, 03:21:11 pm »
You would use a ShapeMerge compound object for that.
George
« Reply #6 on: May 11, 2012, 07:39:50 am »
Let me suggest a better (commercial) alternative (produces cleaner result) - http://www.vg2max.spb.ru/InsertShape.htm
BKE
« Reply #7 on: May 21, 2012, 07:01:51 pm »
"Let me suggest a better (commercial) alternative (produces cleaner result) - http://www.vg2max.spb.ru/InsertShape.htm"
Thanks, George. I am using the trial - without success.  ??? I think I need a step-by-step. Thanks again..
BKE
« Reply #8 on: May 22, 2012, 01:38:19 pm »
Thanks again, George. I just want to pass along that the commercial solution listed above corrupted my scene and I had issues until I removed it as a plug-in. Carlos from iToo support, as well as this tutorial: http://www.cod.edu/people/faculty/pearson/Images/2220-exercise8.pdf has helped.
I used to subdivide my planting regions in REVIT.. but I did not want those additional details in my working drawings. Now I am able to paint my planting/mulch areas right within Max. ;D
George
« Reply #9 on: May 30, 2012, 10:03:18 am »
That's terrible news about InsertShape!  :-[
