Author Topic: Multiple geometry load  (Read 17317 times)
BB1610
« on: March 12, 2009, 01:52:03 pm »
I have a proposal  for loading custom objects in FP3 - to load multiple meshes with turned ON  option `use object dimensions`, so the user don`t have to `click to death` with loading, say, 30 foliage meshes with add procedure, then select mesh for each one, then select for each one also the `use object dimensions` .... instead of it, it`ll be loaded via `select by name` function in 3ds max. Also it would be very useful if in FP3 `geometry list` appear the real names of meshes, instead of `new item`
Re: Multiple geometry load
« Reply #1 on: March 12, 2009, 04:18:46 pm »
Thanks for the input. We will fix these issues and include some option to add multiple items for the next release.
Remember that you can also use Presets to load all parameters (including the Geometry List) with a single click . The only limitation is that custom objects must be available in the scene, and the materials in the scene, material editor or material library.
BB1610
« Reply #2 on: March 15, 2009, 06:16:18 pm »
Wonderfull  :) , btw, the FP3.2b is working with proxies nicely ! Thanks again.
