Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Render farm problem 2
« previous
next »
Print
Pages: [
1
Author
Topic: Render farm problem 2 (Read 4508 times)
TL9672
Newbie
on:
January 16, 2013, 09:31:54 am »
Strange problem, each forth server not rendering all textures of trees, any ideas....
In all servers have installed the same version...
Logged
Administrator
Hero Member
Re: Render farm problem 2
Reply #1 on:
January 16, 2013, 09:45:37 am »
Not all paths are configured automatically in the render nodes. The external libraries (as HQ Plants) must be added manually.
You must include them in "Customize->Configure User Paths->External Files". If you can't run Max interactively in the slaves, the map paths are defined in the following ini file ([BitmapDirs] section):
C:\Documents and Settings\<username>\Local Settings\Application Data\Autodesk\3dsmax\<max version>\enu\3dsmax.ini
Logged
TL9672
Newbie
Reply #2 on:
January 17, 2013, 09:56:07 am »
There is no problem with paths, I Scheck it. everything is correct.
Strange is that each time when I'm start new render, different server have no textures (look at attachment)
Logged
Administrator
Hero Member
Reply #3 on:
January 17, 2013, 10:33:02 am »
What type of network rendering do you use: VRay DR, Backburner... ?
In any case, Forest doesn't handle the textures directly, this process is done by Max. To check if the problem is caused by Forest or not, you could convert the items to stand-alone objects (using Utilities->Forest Tools) and launch a test render.
If that helps, i have found a similar issue in the ChaosGroup forum (in this case using VRay/DR):
http://www.chaosgroup.com/forums/vbulletin/showthread.php?70929-DR-Map-Fail
Logged
TL9672
Newbie
Reply #4 on:
January 17, 2013, 03:18:42 pm »
Yes you are right, it's not Itoo Forest problem, but I still not find problem yet, if I fix I'll right in forum.
Sorry for setback...
Have a nice day
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
