Author Topic: Corners ignored with bevel mode none but distorted geometry with all other modes  (Read 10688 times)
MW0462
I have a curved panel I'm extruding along a path using RailClone.  The seams between the panels are getting stretched along curves in the path.  If I set bevel mode to "none" the seams are correct but corners are ignored so the spacing is all wrong.  If I set the bevel mode to anything else, the seams stretch but the locations are correct.  How do I get the seams to not stretch on curves but also respect corners? Pictures and max file attached.
In order to align with these vertices when Corner > Bevel Mode is set to None, you can add an empty Segment to the Corner input of the Generator. Increasing the Style > Curve Steps value can help improve interpolation quality. Please find attached a revised version of your scene. I hope this helps.
