Author Topic: Unlimited "Building Light Chache" Time with Custom Object  (Read 3435 times)
NP2889
« on: May 19, 2015, 06:46:05 pm »
Hi Guys,
I have a basic scene and use forest pack to scatter an evermotion tree.
After hitting render the Building light cache process is unstoppable and endless.
I encounterd the same problem at a different scene. I can´t close it or stop in a normal way.
Have you any idea what could be the problem?
Re: Unlimited "Building Light Chache" Time with Custom Object
« Reply #1 on: May 20, 2015, 08:27:57 am »
Hi, it seems a renderer issue. I know there were similar problems with the initial releases of V-Ray 3, but it should be already fixed.
What V-Ray version do you use ?
Does it happen also converting the trees with Forest Tools ?
NP2889
« Reply #2 on: July 31, 2015, 12:38:46 pm »
I solved it with deleting the retimer and disable the ClampTex with the Cleaer script
