Author Topic: bug?  (Read 7134 times)
roysgi10
bug?
« on: February 22, 2012, 08:01:26 pm »
is there a knowen bug  (3.8) with object paint when forest applied on multply surface?
Re: bug?
« Reply #1 on: February 22, 2012, 08:11:02 pm »
No, that we know of. What is the problem exactly ?
roysgi10
Re: bug?
« Reply #2 on: February 22, 2012, 08:13:24 pm »
i have notices that if i have more then 4 surfaces  in one forest object- object paint doesnt work
Re: bug?
« Reply #3 on: February 22, 2012, 08:37:39 pm »
It seems to work fine here, at least using a basic scene.
Does it work using the default scattering ? Have you updated the surface's data, clicking the refresh button in the Surfaces rollout ?
roysgi10
Re: bug?
« Reply #4 on: February 22, 2012, 08:47:47 pm »
hi. thanks.
does the surface is made of few object? or it just one mesh with few elements?
can you  try make it with much more complicated object trees - and few of them not just one tree?
 can i send you the scene? more then 20 MG ZIPED.
THANKS.
Roy
Re: bug?
« Reply #5 on: February 22, 2012, 09:09:45 pm »
There are eight surface objects in this test. Theorically, it should work regardless of the number of trees and their complexity.
Please, send us the scene and we will take a look to it. Probably 20 Mb. would be too high for an e-mail, but you can upload it to any sharing files website and send us the link. Or i can give you access to our private FTP, if you prefer so.
roysgi10
Re: bug?
« Reply #6 on: February 22, 2012, 10:01:10 pm »
sent via YOUSENDIT
Re: bug?
« Reply #7 on: February 23, 2012, 10:20:38 am »
Ok, we can confirm the bug.  It happens when using 4 surfaces or more, but only under certain conditions (specially using excluding areas).
As workaround, please collapse your surfaces to 3 or less objects. We will release a maintenance patch (3.8.1) in the next days, including this and other fixes.
roysgi10
Re: bug?
« Reply #8 on: February 23, 2012, 11:55:02 am »
