Author Topic: Path mode and spline material ID  (Read 5531 times)
UB8512
« on: August 02, 2018, 08:39:24 am »
it is somehow possible distribute objects only on spline segments with specific material ID? or dont distribute object on spline segments which are hidden? or can be this done using effects?
Re: Path mode and spline material ID
« Reply #1 on: August 02, 2018, 10:09:49 am »
Thank You for this question.
Unfortunately that is not possible with current version of ForestPack. You probably better off using RailClone in this situation.
Added to todo list.
« Last Edit: August 02, 2018, 10:24:01 am by Rokas »
UB8512
« Reply #2 on: August 03, 2018, 09:53:24 am »
Thanks for adding it to todo list.
I also tried RC, but speed is not good. FP is up to 15x faster.
I need this for trees, which are made with combination growfx(basic shape) and forestpack(needles, leaves, fruits). This combination consume only few MB in memory and also have fast parsing render time.
Having better control over spline segments gives me possibility to have more flexible creation process.
