Author Topic: question about "match color id on map"  (Read 3914 times)
GP4851
« on: November 08, 2016, 05:23:53 am »
Hi,I have some problems with the following:I just learn the new tutorial"Scattering on Vertical Surfaces",and try to use "match color id on map" with a jpg on another plane which I made myself.But the pattern in the plane of tutorial  is correct .No matter how I adjust the density,the pattern is  changeless
 but when I use the jpg on another plane,,the pattern isn't correct,and when I change the density on distribution map,the pattern always changes.
Wonder how to solve it,Thank you ~~
Re: question about "match color id on map"
« Reply #1 on: November 08, 2016, 12:44:40 pm »
I would suggest you to check UV mapping of the problematic object / it's local coordinates (your surface coordinates should correspond with intended Forest object orientation) and that you're using the corresponding channel. Please feel free to send us your scene and we'll look at it here. Thanks in advance.
