Author Topic: No texture in map folder  (Read 6201 times)
SE1984
« on: August 19, 2021, 08:58:13 pm »
There are textures missing in my maps folder as below:
Users\mypc\AppData\Local\Itoo Software\Forest Pack Pro\lib\Presets\Gravel\maps
Users\mypc\AppData\Local\Itoo Software\Forest Pack Pro\lib\Presets\Lawns\maps
Users\mypc\AppData\Local\Itoo Software\Forest Pack Pro\lib\Presets\Meadows\maps
Users\mypc\AppData\Local\Itoo Software\Forest Pack Pro\lib\Presets\Mulch\maps
Users\mypc\AppData\Local\Itoo Software\Forest Pack Pro\lib\Presets\Rugs\maps
Users\mypc\AppData\Local\Itoo Software\Forest Pack Pro\lib\3D\Flowers and grass\maps
Others folder is ok
I have try unistall the above folder using update manager and reinstall sevral time, but still cannot solve the problem, need help!
I am using Forest Pack Pro 7.1.2
« Last Edit: August 19, 2021, 09:03:11 pm by SE1984 »
Forest Pack Pro v7.1.2
SE1984
Re: No texture in map folder
« Reply #1 on: August 20, 2021, 02:40:00 am »
For your info, i have try uminstall forest pack and delete all the maps and effect folder, and reinstall everything, still only the 6 folders have no textures in their map folder, anyone can help me?
« Reply #2 on: August 20, 2021, 08:49:09 am »
Hi, Maps and assets are installed by the Update Manager tool.
Please, open it (Windows menu->Itoo Software->Update Manager), and check if there is some package pending to download.
If needed, you can reinstall everything from Actions->Uninstall All, and clicking the "Install" button in the bottom, to download all packages again.
SE1984
« Reply #3 on: August 20, 2021, 09:54:53 am »
For your info, i did uninstall all package and reinstall using update manager ( I have done that several time ), but still cannot solve the problem, is that a way where i can donwload manually, and then copy and paste all maps into the specify folder?
SE1984
« Reply #4 on: August 20, 2021, 09:56:39 am »
Here is the screen shot of my update manager
« Reply #5 on: August 20, 2021, 10:20:39 am »
Just to add to Carlos' answer. The libraries you listed are older from when we used to aggregate all of the maps into a single folder instead of saving them individually to the library's directory as we do now. You should be able to find this map folder at the following location:
C:\Users\[USERNAME]\AppData\Local\Itoo Software\Forest Pack Pro\maps
In the Update Manager it is a separate download too, so this is the one you want to check is installed.
I hope that helps,
SE1984
« Reply #6 on: August 20, 2021, 02:21:19 pm »
Hi Paul,
Do you mean even though all the library is download separately in the update manager but all the textures will save into the maps folder you mention above?
« Reply #7 on: August 20, 2021, 05:52:09 pm »
That's right, for those libraries that you listed the download is a separate package in download manager that will extract to
Best,
SE1984
« Reply #8 on: August 21, 2021, 06:16:20 am »
Thank you for your help.
I just check the folder and it got all the textures in it, but when i check my material editor, it show a word "JPEG File" as shown as the attach print screen, anyway I will try delete foreat pack in my scene and re-do again, see whether it solve the problem or not.
