Author Topic: Pivot points  (Read 6467 times)
Bobby Parker
Pivot points
« on: January 12, 2018, 05:36:51 pm »
I am having issues with using things like curbs and sidewalks. It seems that the pivot points don't work with a normal workflow and go in the wrong direction. I know I can reverse my spline, but then things go backward. Something like curbs probably should sweep along the top right, so it goes nicely along a curb outline, however, it sweeps from the center. Sidewalks work opposite, too. If needed I can record my screen.
Bobby Parker
Re: Pivot points
« Reply #1 on: January 12, 2018, 07:36:42 pm »
Re: Pivot points
« Reply #2 on: January 15, 2018, 07:22:52 pm »
Thanks for the question. Those style should have a Y Offset parameter that allows you to adjust the way the curb sits on the spline. If for some reason this wasn't working or you wanted to make a permanent change you could also open the style editor and for each segment change the Alignment > Y option to Top.
I hope that help, please let me know if you have any further questions,
Bobby Parker
Re: Pivot points
« Reply #3 on: January 23, 2018, 06:41:23 pm »
Yes, 0'9.8" works for the Y offset. Thank you!
« Last Edit: January 23, 2018, 06:44:37 pm by UC3472 »
