Forest Pack => Forest Pro (*) => Topic started by: NL2911 on August 22, 2012, 06:59:22 pm
Title: Object above eachother
Post by: NL2911 on August 22, 2012, 06:59:22 pm
Is this possible?
I want to scatter objects in a grid but above eachother, but it doesn't seem to work..
This would be awesome!
Title: Re: Object above eachother
Post by: NL2911 on August 22, 2012, 07:00:33 pm
sry i had to change  to UV, i thought i tried that allready
 :D
Post by: iToo on August 22, 2012, 07:10:25 pm
It is also possible in XY mode, using separate surfaces.
Post by: NL2911 on August 22, 2012, 07:22:24 pm
Hmm.. it is not really working as i want.
I have a editbale poly which is a grid of poly's (10 on the x-as [1800mm]  and 3 on the z-as [3400mm] high)
So 30 poly's which i use as a Surface.
My goal is to use this grid to scatter three different objects. But only one object can be on one poly at the time..
 I only achieve one type of object to show, unless i change the offset y, then the other shows up. nut no randomness.
(hard to explain :) )
Post by: NL2911 on August 22, 2012, 07:23:26 pm
ah maybe that approach will work.
Post by: iToo on August 22, 2012, 07:42:34 pm
If you don't get it to work using separate surfaces, please post a screenshot or a test scene.
Post by: NL2911 on August 22, 2012, 08:55:23 pm
(http://3dstudioprins.nl/wp-content/uploads/2012/08/screenshot-forestpro.jpg)
How do i get the randomness?
Post by: iToo on August 23, 2012, 09:32:34 am
Quote
I'm afraid in this case it is necessary to create a separate Forest object by level. Currently Forest uses the same random seed for each surface, so the distributions are identical. (I think we would change this).
But there is an alternative way to get it:
1) Scatter them using an unique UV Surface.
2) Switch to Custom Edit (Tree Editor).
3) Change to the sub-object edit mode and select all items.
4) Click Tree Editor->Randomize
Post by: NL2911 on August 23, 2012, 02:37:10 pm
that would be great!
Its offcourse built for forest and nature scattering but i use it for a lot more and it would be really great to not only focus on trees and plants.
I will try your workflow later on. thanks!
