Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Object Visibility
« previous
next »
Print
Pages: [
1
Author
Topic: Object Visibility (Read 3272 times)
amitgedia
Full Member
Object Visibility
on:
July 29, 2023, 11:02:16 am »
Hi Guys,
I have prepared a scene where i have FPP objects in it.
I wanted to keep the objects in viewport but dont want them to render in the image. By not rendering them in the scene i will atleast get the shadows casted by the object but the actual object will not get rendered.
Any possibility for this situation as to how can i achieve it.
I right clicked the object properties of the FPP object and clicked off "visible to camera" but still they render in the scene.
Any help would be useful.
Attaching the file with marked section which i don't want in the image.
Logged
ITOOSOFT
Hero Member
Re: Object Visibility
Reply #1 on:
July 31, 2023, 08:38:58 am »
Which renderer are you using? In some renderers (like for example the Corona Renderer) you should unmark the mentioned visibility option (
Visible to Camera
directly for used
Custom Objects
. That should do the trick.
Logged
amitgedia
Full Member
Reply #2 on:
July 31, 2023, 09:17:21 am »
Hi Michal,
Sorry I didnt mention the software, its 3dsmax 2023, Corona HF1, FP 8.2.2.
The steps that you mentioned did the trick. It was so simple. Thanks for your solution.
Last Edit: July 31, 2023, 01:39:15 pm by amitgedia
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Object Visibility
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
