Author Topic: When objects are Xreffed their scene units scale aren't remembered  (Read 8030 times)
alexrecentspaces
  • Recent Spaces
    • recentspaces.com
Small bug or something that can be improved:
If I have a FP with some objects loaded in via the Library, and I have those objects come in to the scene as xrefs rather than embedding into the scene, and those objects are not in the same units as the scene, every time I open the max file there is a scene unit scale mismatch and I have to hit "ok" for every object, which can take a long time to do if there are lots of them. It looks like the FP/max scene isn't "remembering" that you are wanting to rescale/adapt them all to the scene units.
Alex York
Recent Spaces
Re: When objects are Xreffed their scene units scale aren't remembered
« Reply #1 on: June 07, 2017, 01:30:08 pm »
The annoying XRef Object Merge: Units Mismatch warning window issue in 3ds Max 2016 was reported to Autodesk and as mentioned in this related post: "Unfortunately, as this issue isn't related to our plug-in at all (it'll happen in any scene using several XRefs that doesn't match the scene unit set-up), we can't do much more in this case. Thanks for your comprehension."
As far as I know, there's no similar "problem" in the 3ds Max 2017 / 3ds Max 2018.
Best regadrs,
alexrecentspaces
  • Recent Spaces
    • recentspaces.com
« Reply #2 on: June 07, 2017, 01:31:54 pm »
Best regadrs,
Ah! That's great to hear, if it's been fixed by AD already... thanks very much.
Alex York
Recent Spaces
K Gazzard
    • The Ruby Cube | Boutique Rendering Studio
« Reply #3 on: November 09, 2020, 01:18:42 pm »
Hi, I was wondering if there has been any update on this? I found an old post on Autodesk pointing to a script called 'Silentium' - however it doesn't work for max 2021.
-- Ruby Cube --
« Reply #4 on: November 09, 2020, 01:32:20 pm »
There is no other alternative that I know.
FP7 library browser will skip those pop ups.
IM1808
« Reply #5 on: January 12, 2021, 05:45:24 pm »
It's strange, I loaded an object with the forest and checking "Xref to library" to save memory. But the unit system of this object is the same as the scene.
Why this problem if the files are the same?
« Reply #6 on: January 13, 2021, 08:07:22 am »
Hi, would You please explain the situation a bit more in depth, i did not understand Your situation/error.
IM1808
« Reply #7 on: January 13, 2021, 08:52:34 am »
sorry for my request, I saw that I had unchecked "respect unit file" in the unit configuration while I was opening the source file ...
Is there any plug-in or script to convert multiple file units directly without opening one by one and saving one by one?
it is really boring, i have a big librairie and the last files have not the good unit setup. It will be too long to make one by one...
Thx
