Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Problem with net render (render farm) need help!
« previous
next »
Print
Pages: [
1
Author
Topic: Problem with net render (render farm) need help! (Read 7436 times)
JK9969
Newbie
on:
September 26, 2015, 12:00:53 pm »
Hi! I am trying to render animation on render farm, but i have big problem. on some frames i have missing forest objects. look pls video
https://yadi.sk/d/1FKOBUeRjLCfu
https://yadi.sk/d/BymGWUrZjLDPi
Can anybody help me?
Last Edit: September 26, 2015, 12:13:51 pm by JK9969
Logged
Administrator
Hero Member
Re: Problem with net render (render farm) need help!
Reply #1 on:
September 27, 2015, 08:59:33 am »
Hi, it seems some of the render nodes has not Forest installed or uses a different version.
Please, check this
FAQ entry
to see the most common issues with render nodes.
I suggest to check each one of them using a test scene. Once identified, apply the fixes described in the FAQ. I hope that helps.
Logged
JK9969
Newbie
Reply #2 on:
October 01, 2015, 05:28:36 pm »
all server has forest 4.4.0 vers, installed as render node
Logged
ITOOSOFT
Hero Member
Reply #3 on:
October 01, 2015, 06:16:54 pm »
Can you please send us a simplified version of that scene (ideally containing just necessary parts as problematic Forest objects) through
WeTransfer
to support@itoosoft.com to analyse it here? Thanks in advance.
Logged
QE1198
Newbie
Reply #4 on:
October 08, 2015, 11:32:47 am »
Im having the exact same problem. Very frustating, all computers running the excact same version of max and Forest Pro. The first 40 frames are working, then the render servers starts to not render the Forest Pro object!
Logged
ITOOSOFT
Hero Member
Reply #5 on:
October 08, 2015, 11:51:02 am »
Would you mind to send us your scene (ideally containing just necessary parts as problematic Forest objects) through
WeTransfer
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
