Author Topic: Vegetation on tree bases.  (Read 2756 times)
thanulee
    • Yell Images
« on: August 31, 2016, 10:43:48 pm »
Hi, can i somehow have vegetation around my object without doing it by hard? For example i got 1 forest with trees and one with low vegetation or rocks. Is there a way so the rocks are scattered around the trees automatically?
thanks
Re: Vegetation on tree bases.
« Reply #1 on: September 01, 2016, 10:27:49 am »
That's easily feasible by using the Areas - Falloff feature in a following way:
(1) Add the "trees" Forest object as excluding area inside of the "rocks" one
(2) Optionally, under Properties lower the Scale (like in attached screen-shot to 10%)
(3) Enable the Falloff - Density and adjust the Exclude amount as needed
(4) Mark the Invert Curve check-box to apply it around this Exclude Area
Hope that helps. Feel free to check our on-line reference guide - how to "To add scatter items around the perimeter of an exclude object" for more detailed info.
thanulee
    • Yell Images
« Reply #2 on: September 01, 2016, 01:44:05 pm »
Great! thanks a lot!!
