Author Topic: Random selection in forestpack (custom edit mode)  (Read 5696 times)
simon.keay
« on: April 22, 2013, 06:38:53 pm »
I wonder if someone can help-
I have a forest set out in a certain way which I've done using custom edit. I then want to randomly transform the rotation.
Is there a way to make this random selection other than to click away at random?
Thanks in advance!
Re: Random selection in forestpack (custom edit mode)
« Reply #1 on: April 22, 2013, 07:38:30 pm »
Do you want to randomly rotate only to certain items, or what is the reason to not use Transform->Random ?
In this case, you can do this:
1) Create a separate Forest object with only the selected items, using Tree Editor->Detach Selection.
2) In the new Forest, apply Transform->Rotation.
3) Select the items in Custom Edit mode, and click Tree Editor->Store Transform (the transformations are stored within each item, and Random->Transform is disabled).
4) Merge the two Forests, using Tree Editor->Attach Single.
alexrecentspaces
  • Recent Spaces
    • recentspaces.com
« Reply #2 on: April 25, 2013, 11:39:43 am »
This is a very useful post! Thanks.
Alex York
Recent Spaces
